LS460 Oil Replacement Reminder / MAINT REQD Indicator Reset
После замены масла и прочего техобслуживания LS460h (USF40 L-, 1UR-FSE), сделайте так:
1) Switch the power source to IG-ON. Then, use the TRIP switch to turn ON the "TRIP A" display on the multi-information display.
2) Switch the power source to OFF. While pushing the RESET switch, switch the power source to IG-ON.
3) With the power source in the IG-ON mode, keep holding the RESET switch (for at least five seconds) with the multi-information display counting down as shown below.
4) When the reset operation is complete, the multi-information display will display “COMPLETE”. At this time, release the RESET switch. After 6 seconds, the “COMPLETE” display will turn off, indicating that the resetting is complete.
Как это делать на других моделях см. в http://forum.mek1.ru/viewtopic.php?t=2625 .
В viewtopic.php?f=8&t=85 описание "сброса" индикатора износа тормозных колодок LS460.
В viewtopic.php?f=8&t=179 - "процедура" сброса индикатора состояния салонного фильтра (Air Conditioning Filter Maintenance Date Reset).
В viewtopic.php?f=8&t=214 "подробности" удаления информационного сообщения "Injector maintenance required".
В viewtopic.php?f=8&t=97 "борьба" с незаведением после разрядки аккумулятора.
p.s. неплохо, что это кому-то помогло :) например, автору темы http://forum.autocd.ru/viewtopic.php?t=16565
"OIL MAINT REQD SOON" message on GS300 Inform. Display
GS300 (2006MY)
"Oil Maintenance Information Indication Mode:
● This mode must be reset whenever the engine oil is changed. Then, after the vehicle is driven 4,500 miles and the ignition is turned ON, the display will indicate that the oil must be hanged soon. After the vehicle is driven 5,000 miles, the display will indicate that the oil must be changed.(provision available for the USA only)
● During resetting, the display will show "OIL MILEAGE RESET", which will go OFF when the reset is completed.
Oil maintenance Information Mode Reset Operation
-After 1.5 seconds have elapsed with the ignition ON, press the trip switch ON. located inside the switch box on the left side of the instrument panel.
-Keep the trip switch pressed for 5 seconds while the display shows "OIL MILEAGE RESET", and the master warning light turns ON.
-When the reset is completed, the "OIL MILEAGE RESET" and the master warning light will turn OFF."
А вот так это делается у Lexus LS430:
В этом вложении TSB "LEXUS GENUINE FUEL INJECTOR CLEANER" (EG-5106) с описанием процедуры RESET COMBINATION METER после fuel injector maintenance procedure for using fuel injector cleaner.
___LEXUS GENUINE FUEL INJECTOR CLEANER.pdf
(70.37 КБ) 689 скачиваний
Reset Injector Maintenance Required Message
Некоторые современные автомобили* "наровят" кое-что требовать от своих владельцев, например, сброс (Reset) такого: "Injector Maintenance Required Message".
Вот что на это в этой связи отмечает Mike McCarthy, государственный уполномоченный Агентства по защите окружающей среды Калифорнии (CARB):
"... I did finally get an answer from Toyota. The Injector Maintenance Required message does exist but only on Russian specification vehicles, not US or Euro spec vehicles.
It may also exist on China spec vehicles and while I don't have specifics on what the required maintenace actually is, the speculation is that it is some sort of injector cleaning based on the poor fuel quality in Russia and China...
Off. Mitsubishi Outlander Service Reminder reset:
Процедуры сброса сообщения о замене масла (Reset the Engine Oil Life System) в GMC Acadia a 2007 описаны в http://alflash.com.ua/acadia/acadia.htm
semirek
Re: LS460 Oil Replacement Reminder / MAINT REQD Indicator Re
Сообщение semirek »
Сайт http://www.oilreset.com/ - информация по сбросу сервисного интервала по замене масла почти на все авто американского рынка
